Hi guys
i just picked up a 2012 f30 320d, I want to swap the rear lights for led lights with sequential indicators.
does anyone  have any for sale or can recommend any specific ones?
im in york but happy to travel. Ideally plug and play, no coding etc unless anyone on here is able to help with it? Thanks everyone
Hi Mike
Before you part with any hard earned cash first check if LED or OLED Rear Lamps were an option for your model. If they were then things will be easier, but at a minimum I think you would need the Inner and Outer Light units, wiring harness adapters plus yes they will need coding I suspect to get them working correctly.
Someone with INPA/ISTA or similar should be able to do it for you (A BMW Specialist or good Independent) or perhaps a member on here near to you.
There are a number of Specialist BMW dismantlers I would Google and find one as a source of parts but only if they were an option, if they weren't then things could get complicated.
