Went to have a look at the pdc module as ista only shows up as 1 failed sensor so should still work. I never expected to find this. Expected to find more electrics in here?
🤣😂🤣 If in doubt chuck it out !!! Strikes again
From Memory there is a plastic formed insert that sits below the spare that houses the PDC
If the scan is telling you which sensor I would first check the connector at the sensor clean and refit they often get damp and throw a wobbler..If that doesn't cure it change it fairly easy job.
