Hi
My E90 320d drives well an smokes white untill she is warm then smoke fades an goes away an come back but when it comes back its small little , however the turbo isnt boosting also , the compression is bad , what can the problem be ??
Is this a genuine post ??
Sounds like a completely unloved badly looked after car and if your still driving it that underlines that fact. Performance must be rubbish as will be MPG
Smoke, Investigate and fix? Low compression (how do you know?) = Worn engine investigate and fix/replace?? No boost? investigate and fix/replace
    5. 2
