Hi everyone,  so I recently got my first 325 (2007) however the power steering has gone. I have checked and there is enough steering fluid. Any ideas how I can fix this ? thanks
Morning Adam
First has your car got standard Hydro power steering or Active power steering?
If you have standard steering it could be the pump or the rack ? If you have active steering the pump and rack are different and you have a Control unit.
Take a look at www.realoem.com put the last 7 digits of your Vin number in the search box and it will call up your model, then check the steering section.
If you have active steering check the fusses and any relays.
    3. 2
      filter change recomendations
    • Mama1809 earned a badge
    • Alan520d earned a badge
    • First Bima earned a badge
    • Rob Lee earned a badge
