X1 instrument cluster randomly displays errors intermittently
Water leak at sharkfin aerial
Looking for some help. 2010 116i M sport with the 2.0na engine. When cold, car ticks over perfectly. After about 15 mins of driving when idling you can feel it getting a little bit rough. Nothing too bad, but the longer you idle the worse it gets. No EML. When running car runs perfectly not a flicker. Today left it idling for 10mins after I felt it and then revs started to fluctuate but still no eml. OBD scanner can’t pick anything up. Turned it off and back on and was still rough but only a little bit like when it just starts. Anyone had anything similar or can point me in a direction of where I should start looking?
