Evening all
9
9
Thanks Dave & Stu, this is a big help, thanks. I have the original key which starts the car. The locking doesn't work, but I'm not bothered. I took it to a copy shop. The guy couldn't get a reading from the transponder. (That's the immobiliser, right?) So I said to him to make me a copy anyway. 25 quid. The copy operates the doors and the ignition but not the starter. So I now have a key with a transponder chip *SEE PHOTO* (I assume the red bit) and I need to copy the code from the original key and copy it into the new one. I did see a thing online but I don't know if it'll copy. https://www.amazon.es/-/en/gp/product/B0DY7VCTQZ/ref=ox_sc_act_title_1?smid=A18I26BYARIXXP&psc=1 -
hi Dave, I had a look there and if its there I couldn't find it, the only other place it seems to suggest is to do with the BC button on the indicator lever but I have tried that as well and no joy, it may be that there is some sort of procedure which has to be followed in the right order but until now I am at a loss. cheers Paneuro. -
9
https://www.ebay.co.uk/itm/256870344200?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=P-zHGgE2SZ6&sssrc=4429486&ssuid=Ht4YuRv-Sdq&var=&widget_ver=artemis&media=COPY
