I have an 1997 840Ci that lost the trans computer and now mechanic states the wiring harness is burnt need to locate some mechanic in nyc area that can fix vehicle
Morning Luis
There is an internal harness in the transmission plus the external harness. Which one is toast ?
If it is the external harness between box and EGS then either an Auto Electrician to cut out damaged sections and replace/repair them then use www.realoem (classic section) put the last 7 digits of your Vin into the search box it will bring up your model.
Sorry can't help with a mechanic but here in the UK we have a Register of BMW Specialists maybe you have similar there? Or maybe talk with Pelican Parts they may have more local knowledge
      Alloy wheels
