 2013 650i, so after having to brake really hard for a cyclist I'm getting all these faults coming up,anyone got any ideas how to fix them,have checked all the battery connections nothing seemed loose or disconnected.
Thanks in advance
Kelvin
Morning Kelvin
Most of the faults will have come through the emergency use of the ABS as the other chassis faults will likely be linked. When was it's last service? What is the Brake Pad condition?
Nice car by the way. First try disconnecting the battery for 30mins (a dealer trick) that should re-set everything, while the battery is disconnected test it for voltage anything below 12.5 volts will show either a flat or failing battery. If it's low try charging it fully (overnight minimum) With a fully charged battery reconnect and start the car if there is a genuine fault with the ABS faults will re-occur. If nothing returns it could just be a low voltage glitch or a sticky ABS solenoid as we don't need them that often.
As an aside I don't know where you are but in Sussex a lot of cyclists wear the Sky team colours (Black) really useful on a murky morning ??
Good Luck
