E84 Window reset
Hi, I have a 2013 BMW X1 E84. My battery ran out a couple days ago. After a charge its fine now but theres an issue with drivers window. Doing the 1 touch, the window rolls up but when gets to the top it rolls back down a few inches. Its fine when rolling down. Ive searched online and I believe the window needs resetting. Ive followed the instructions from different sites. Some say to roll window down and keep switch pressed for 5 seconds or 15 seconds and then do the same going upwards but after doing this I still have same issue.
Does anyone know what Im doing wrong? Is there a difference for resetting a X1/E84?
Thanks
Hi Brian
As I recall (not done this on an X1 but should work)
Sit in the car close the doors key in the ignition and start the engine to ensure there is no fluctuation with power. Window down release button, re-press the button and hold for 15 secs now window up hold the button until the window is fully up release the button now re-press the button and hold for 15 secs.
Your windows should now be re-set
That has worked for me in my X5, brother inlaws 5 series and a couple of 3 series so fingers and toes crossed
Good luck
