Do you know if I can change the side mirrors on my 2018 430i to side mirrors with cameras with sensors that will display on my car screen when I turn on my turn signals?
Thanks,
Hi Marc
Not sure what you are asking here Marc, I know you can get "Back Up with Top View" camera's "Lane Change Warning" and "Surround View" I believe all functions use the same camera.
Fortunately it's not as straight forward as just changing the mirrors, as they will need coding to your car assuming the looms and other stuff are in place. BMW will either tell you impossible or will want several body parts as payment 😂
An interesting project I would begin with www.reaoem.com put the last 7 digits of your Vin into the search box it will cal up a parts list for your model the check the vehicle trim section to see if it was an option. In the parts list you will see some thing like S3AHA   followed by Yes or No and a Part number in blue this is the part you will need to find.
So assuming you don't want to donate a body part or two I would contact the specialist vehicle dismantlers, bet they will still be expensive but nowhere near BMW new cost. Plus you will need someone with ISTA/INPA who can then code them to your chassis, or buy a copy for yourself and mount it on a laptop
      520d advice
    3. 13
      Fuel rail pressure problems.
      Would you buy this car?
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
