I have a 730 2008 automatic.
Car won't start battery seems fine.
Press button to start and nothing all dash lights come on as normal.
Something about pre heat comes on. At a loss with it can anybody help
Thanks
Morning Craig
Pre-heat are the glow plugs and or the glow plug relay. If the mornings are cold that may be the issue but you need a Diagnostic scan to be sure. Have you tried starting in N not P just in case it is the inhibitor switch.
      Water leak at sharkfin aerial
    • Driverbus70 earned a badge
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
