Hi all, looks like I have a seal failure as moisture looks like it is in the side panel light on one side of the E64. Where would I find the bulb spec for this light? Are they readily available.
The actual bulb holder may also need to be replaced but cannot find any new, only used. Any pointes on buying new ones as I am suspecting the seal will go on used ones and I then have the same problem.
Any advice gratefully received.
Paul
      Alloy wheels
    • Gouden earned a badge
    • Markc earned a badge
    • Neil Stokes earned a badge
    • Mish earned a badge
    • Paul M went up a rank
