Hi all, looks like I have a seal failure as moisture looks like it is in the side panel light on one side of the E64. Where would I find the bulb spec for this light? Are they readily available.
The actual bulb holder may also need to be replaced but cannot find any new, only used. Any pointes on buying new ones as I am suspecting the seal will go on used ones and I then have the same problem.
Any advice gratefully received.
Paul
      Z3 airbag wiring,
      Z3 airbag wiring,
      Bmw x1 2012 won't start
    • JayMe earned a badge
    • Andrewkuk earned a badge
    • DAW90 earned a badge
    • Max123 earned a badge
