I found this nylon van pipe nestled behind the oil filter housing but can’t see where it’s likely to go,can anyone help me locate it?
Hi Bruce
There is a transmission breather down there see if you can trace it back also check www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model. Then look in the relevant section and see where the transmission breather is fitted.
  On 5/1/2022 at 6:32 AM, Greydog said:
Hi Bruce
Expand
Thank you
Found the origin of the vacuum pipe is the transfer box for the fwd,don’t where it fits into though.
That's the one Bruce there should be tandem clips that fix it to the other pipes you should get some clues from the small drawings on realoem. The end is open to atmosphere I believe
