Hi guys I’m Rickie ,  new to the forum . Was looking for a petrol tank and sending unit for a e28 525e 1994  bimmer . Anyone know of one . The sender seems harder to find . It’s the one with the foot type filter on the bottom .
Rickie
Morning Rickie
Seems you have a great project on the go
Take a look at www.realoem.com in the Classic section put the last 7 Digits of your Vin into the search box, It will call up your model then search the relevant section once you find the part then double click the part number and you should get a list of alternates and other models it was used in which may help. Also contact BMW customer support they have a great Classic section and may be able to help.
      Drivers side wiper not flush
    2. 4
      Weird X5 Top End Noise
    3. 5
      Engine Failed with broken timing chain
    4. 5
    5. 4
      Air bag fault
    • Pipes69 earned a badge
    • Dimitris went up a rank
    • Norrimac earned a badge
    • Pete Lancashire earned a badge
    • Gunslinger76 earned a badge
