The suspension on my BMW X5 keeps going down every week what could be the problem
Hi Barry
The simple answer is, you have a leak where the leaks is will dictate how simple/expensive it is to fix.
It could be a leaking airbag, the air control valve or the compressor. The  question is how are your DIY capabilities?
If you have reasonable DIY skills the system isn't particularly complicated and the probability is it is a leaking air bag.
    5. 12
    • TigerWhite earned a badge
    • Pipes69 earned a badge
