Morning George
I am assuming your car is Diesel ? If it is then the injectors should be the same. You can check www.realoem.com if you aren;t aware it is a BMW Online parts list either search by car type/year or put the last 7 digits of your Vin into the search box it will bring up your model. Once you have the part number double click it will give you a list of alternates/models it was used in. Or check it against the 2.5 engine by a new search.
If your friends injectors are used get them tested you don't want to put in something that may be worse than those you have. Also fit new seals and "O" rings
