Question: Which tool is recommended for BMW odometer correction? YANHUA Digimaster 3 or CGDI CG Pro 9S12 programmer?
Recommended: If you read and write more BMW ECU jobs including mileage adjustment or immobilizer reset then CGDI Pro is recommended; If you are doing more odometer corrections not only for BMW then Digimaster 3 is recommended.
1. YANHUA Digimaster III
How-to-Choose-BMW-Mileage-Correction-Too
Price: US$923
Features
1. Odometer correction
2. Audio Decoding
3. Airbag Resetting
4. Engine ECU programming
5. Key programming for BMW & Mercedes Benz
Among them, odometer correction is the main function of Digimaster 3 and covering a wide range of car models.
Odometer Correction Car Model List
http://forobd2tool.com/wp-content/download/Digimaster_3/digimaster_iii_newest_car_list.pdf
http://forobd2tool.com/wp-content/download/Digimaster_3/digimaster_3_digimaster_iii_original_odometer_correction_master_new_cars_list.pdf
Digimaster 3 2000-2014 BMW CAS Supported List:
System Car Model Functions
CAS1 912DG128(3K91D) BMW 7 Series 2001-2004(E65) 1. Mileage Adjustment: supported by OBD or BDM(wired) approach to CAS, instruments need to remove the handle.
2. Key Match: supported by OBD or BDM(connection) to achieve.
CAS2 9S12DG256(2K79X) BMW 1 Series 2004-2006(E87),
BMW 3 Series 2005-2006(E90), BMW 5 Series 2004-2006(E60), BMW 6 Series 2004-2007(E63/E64), BMW 7 Series 2004-2008(E66)
2. Key Match: supported by BDM(connection) to achieve.
CAS3 9S12DG256(0L01Y) BMW 1 Series 2007(E87), BMW 3 Series 2007(E90), BMW 5 Series 2007(E60), BMW 6 Series 2008(E63/E64), BMW X5 Series 2007(E70) 1. Mileage Adjustment: Supported by OBD or BDM (wired) approach to CAS, instruments need to remove the handle.
2. Key Match: supported by OBD or BDM (connection) to achieve.
CAS3+ 9S12XDP512(0L15Y) BMW 1 Series 2008-2011(E87), BMW 3 Series 2008-2012(E90), BMW 5 Series 2008-2010(E60), BMW 6 Series 2009-2010(E63/E64), BMW X1 Series 2010-2014(E84), BMW X5 Series 2008-2013(E70), BMW X6 Series 2008-2014(E71), BMW Z4 Series 2010-2013(E89) 1. Mileage Adjustment: Supported by OBD or BDM (wired) approach to CAS, instruments need to remove the handle.
2. Key Match: supported.by OBD or BDM (connection) to achieve. For now only CAS3 + basically way to do key with OBD.
CAS4   9S12XDP512(1L15Y) 9S12XEP100(5M48H) BMW 5 Series 2010-2014(F07/F10/F11/F18), BMW 6 Series 2011-2013(F12/F13), BMW 7 Series 2009-2013(F01/F02), BMW X3 Series 2011-2013(F25) 1. Mileage Adjustment: Supported by OBD or BDM (wired) approach to CAS, instruments need to remove the handle.                        2. Key Match: supported.by BDM (connection) to achieve.Currently supports the first half of 2012, the second half of CAS4 + version does not support, in 2010 after CAS is 5M48H the CPU.
FEM BMW 1 Series 2012-2014(F20), BMW 3 Series 2013-2014(F30/F35), BMW X5 Series 2014(F15) Mileage Adjustment: support, by adding FEM filter to achieve. There are two versions, a direct increase in the FEM module, another is added to the back of instrument.
YANHUA 35080 V6 adapter supports BMW 35080 & 160DOWQ series chip.
YANHUA CAS BDM adapter supports BMW CAS2, CAS3, until 2010 newest CAS4.
Digimaster 3 wiring diagram & instructions path:
Meter system >> Europe >> BMW >> Series(E90) >> Meter adjustment >> 35080/ 35080 V6/ D80D0WQ
(For more supported car models, please contact online service.)
2. CGDI CG Pro 9S12 Programmer
Price: €421
Features
1. Read & write BMW CAS1-4, Porsche BCM, Mercedes-Benz EIS, Audi BCM2 Etc anti-theft computer.
2. Support 80% of the 35160WT, 35080, 35128 on market.
3. Free new CAS4 DB25 & TMS370 adapters support to read CAS4 without removing chip.
CGDI 9S12 BMW Supported List:
CAS4+ 5M48H/1N35H (9S12XEP100)
CAS4 1L15Y (9S12XDP512)
CAS3 0L15Y/0M23S (9S12XDP512 including CAS3+ series)
CAS3 0L01Y (9S12DG256)
CAS2 0L01Y/2K79X (9S12DG256)
CAS2/E66 0L01Y/2K79X (9S12DG256)
CAS1 0K50E (912DT128A Write FLASH data online)
EWS4 0L86D/1L86D/2L86D (9S12DJ64)
EWS3 0D46J/2D47J (MC68HC711EA9)
EWS2 1D47J (MC68HC711EA9)
*CG Pro 9S12 is able to read & write above data for mileage correction & immobilizer reset (For more supported car models, please contact online service).
CG Pro 9S12 Calibrate Mileage for BMW 160D Steps
The mileage of original car is 101024km. Miles are stored in 160D chip.
1. Remove BMW meter instrument from vehicle.
2. Clean 160D chip, put it into CGDI adapter.
3. Select car model to read & save original data files: Dashboard >> BMW >> 160DQ(mode 1) >> Read >> Save
4.input new mileage to start adjusting odometer: 72992km
5. Read again to save new data files.
Done.
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
