Hi
daft question, I’m sure someone will know. But which flaming oil should I use for an oil change? I’m leaning towards 5w-30 but then some say 5w-40 or even 04-LL. I just don’t know. BMW 320d 2005 (163 bhp)
thank you
Morning James
The only Daft Question is the one you wished you'd asked
BMW specify a range of oils for use in different climates check the hand book. 5-30 fully synthetic is normal in the UK and Europe, 5-40 fully synthetic in extreme conditions (Heat) or in a very high mileage engine
I use Castrol Magnatec so does my Brother Inlaw in his diesel
Hope this helps
  • Thanks 1
1 hour ago, Greydog said:
Morning James
Hope this helps
Morning Dave
Thank you for your advice. I’ll get some ordered. Appreciate your help.
Thank you
James
