Hi as anyone replaced rear self levelling shock absorbers, for standard non levelling shock absorbers as they are £100 compared to £800.
What happens to the wiring.
Thanks John
Morning John
As the wiring will not be connected to anything the system will think there is a Fault so you will get warnings about inactive self leveling suspension. I would think it is possible to "Code" out the warnings using ISTA/INPA
There may be further complications if you have self levelling on all 4 corners when it comes to coding out the warnings. I don't know if leaving the warning will cause a limp mode situation with the car thinking it has suspension failure.
I have coded out several X5 and a couple of 5 series with rear only Air suspension when the owners have gone to conventional springs. Nothing on a car as new as yours though. My personal preference is OEM so my X% still runs rear self leveling air suspension.
