Hi got a f30 and when you put it in reverse the camera doesnt work, also cant do a idrive reset!
help please thanks
Morning Mohammed
You could try a Battery reset, disconnect the Neg first some say touch the Pos and Neg together to discharge any static in the system (never done that myself) Leave it disconnected for at least 15 mins, if you can't reset your Idrive then you will need a diagnostic check to point you in the right direction for a fix
    3. 13
    • Mish earned a badge
    • Bmw90 jack earned a badge
