Rear deck not locking down.
BMW 318i boot locked can’t get into
I forgot to mention that the trunk won't open because the battery is dead; and nothing will open it. Door will open with emergency key; but not for the trunk. I had not driven it since the middle of December.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
24
hey X5smw., this is DDONNY. I tried a pair of cheap pair of jumper cables; hooked it up to what looks like charging points under the hood in my Mercedes 2003 CLK430, and it burned quickly. Would a charger work? + on the red clip and black clip - grounding a bolt or nut on the steel? What I see is on the top of driver's fender with two fairly large wires attached to somewhere that appears to be +.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
E70 Drivers door won't open inside or out
Cheers Dave, I assume I need to remove the seat out as struggling to get to the rear bolt as door won't open. Cid -
Angel eye install…. Stupid glue!
Morning Stu That looks brutal 🤣 nice and bright though You didn't have the metal high speed saw blades then 🤣 Dave -
On or Off Quick E30 320 Question
Hi everyone Just a quick question regarding the overhead console computer as I cannot remember whether it should be All on or off prior to starting the car? I have fitted a new battery and I'm having blond moment lol (no offence intended). Currently prior to cranking the car over it is all lit up and I'm sure it wasn't like that beforehand and then mostly goes out during cranking. Not sure if I have to reset something so any help and advice would be most welcome.
