Changing manual E61 gearbox/differential oil?
filter change recomendations
Thanks for your input. I checked the the DC Voltage with a meter on either side of the fuses (152 and 182) on top ,so I know the fuses are good I also checked the relay 'on the bench' and it's functioning too. Maybe the car needs a reset with a BMW Diagnostics kit as there is still an icon on the dashboard which will not clear? -
