Hi, I have a completely stock e93 that was throwing a 30FF code, so I installed a new CP as well as replacing the vacuum lines that attach to the BOV. The car is driving great compared to pre-install but the check engine light came on after install, along with "engine malfunction: reduced power." I can't see how the TMAP could be failing because I have no power mods just yet, I don't think there is any possibility my boost is over 19psi. And what does the IAT (P0112) have in common with all these symptoms?
Any possibilities as to what could be causing these codes? Would really appreciate the help.
Morning Hunter
Remember that General codes 30ff and PO112 are often symptoms not necessarily the cause
You refer to BOV ? do you have an aftermarket Blow Off Valve? the standard turbo actuators operate at 9 psi yet you refer to 19 psi. The higher the boost the hotter the intake air temp is which may well put it outside normal operating parameters and throw the code.
I would go very carefully back over the work done and check everything, vacuum line routing, make sure none are kinked absolutely no leaks.
I would also invest in a BMW capable diagnostic scanner it will give far more accurate information
Good luck sorting it
  • 2 years later...
2009 bmw 335i convertible e93 n54 engine getting engine malfunction: reduced power, how do i fix? Made numerous changes including installing new turbos.
Morning Rob
Fail Safe (Reduced Power) it is there to protect the engine and other components
Fail Safe can be triggered by the gearbox as anexample, when was the gearbox last serviced?
The engine has a whole raft of sensors and their wiring that can trigger the same condition so I would start with a Full Diagnostic scan (you have something like 100 plus systems and sensors) once you have a list of fault codes we will have a better chance of helping.
