Hi
Bmw f26 x4 2.0 diesel 2017
Have a vibration noise inside car around passenger area, exactly 1500rpm then stops, sounds like metal touching metal high frequency, stationary holding the revs or drive it through the gears,can't pin it down driving me mad
Hi John
And once you know it's there you can't ignore it !!
All I can suggest is first empty all the storage trays of everything see if that helps. Check the seat for any loose trim or plugs/switches (underneath) If it's behind the dash the task changes as the only way to find it is to remove as many dash covers as possible then with the revs around 1500rpm touch press stuff until you find the culprit. Then either Mastic or foam to keep them apart.
Good Luck with the hunt
  • 1 year later...
Morning Andy
You have responded to a 2 year old post, sadly many people do not close out posts and after 2 years may not even own the car anymore
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
