Advice please
No emergency door lock
Hi my Battery is flat, my fob does not work. Removed caps at the side of the door handles, no emergency keyholes/locks present. I do have the fob keys, but no lock to put them in. BMW 420d 2014 Any ideas how to get in the car? Any help appreciated Thank you -
6
Morning Alexander Welcome to the Forum Paul used Liquid Moly additive I beleive, do remember that if the seals are hardening through age this will work if the seals have gone it can't do much Dave -
Bmw x4 2015 angel eyes
Morning Ben Welcome to the Forum Never actually seen this but from what I read it is normally the Halo LED's failing and needing replacement Dave
