Bmw E61 number plate light fault.
Drivers side wiper not flush
My x5 drivers side did this and it was the spring had lost its tension. I just bought another from eBay and fitted it in 5 minutes. job done! -
Hey, Just seeing whether there is a common problem or if someone has an easy fix? My drivers windscreen wiper doesn't sit flush to the screen when moving, leaving patches on the glass. I have replaced the wiper blade, and had a go at bending the arm, but the problem still remains. Any hints or tips would be great appreciated. -
Weird X5 Top End Noise
Hi guys, turned out it was the 'Idler Pulley' in the belt. Local autoshop figured it out. $100 repair. Thanks again for your help, appreciated! Norm.- 2
5
Engine Failed with broken timing chain
Is there Any way of making the useless heads lights better apart from fitting high output bulbs ? -
5
It's now 4 years down the line and the engine was rebuilt by a local BMW wise kid. Has been running fine now that the Cats been muted and the ECU told that the cat ran off , runs better with more mpg and now on 109K miles.
