I have an automatic 2008 E93 335i and the tranny has always been a bit rough but I never received any codes from it. However, last night I got my codes read at Autozone after going through a transmission malfunction and I had the codes listed below. I believe that this is due to the Transmission Control Module going out, but I'm not too sure. Could anyone help me diagnose this? I don't want to make any purchases before I know for sure.
symptoms are...
- rough gear shifts (esp 3rd - 4th)
- random down/upshifts at low speeds
- rpm flutters in neutral
- transmission malfunction every so often
Any help or suggestions are appreciated!!!
315186924_171241265516522_2522389894585426393_n.jpg?stp=cp6_dst-jpg&_nc_cat=110&ccb=1-7&_nc_sid=5cd70e&_nc_ohc=J-oA9WjsiwEAX8H9zOx&_nc_ht=scontent-lga3-2.xx&oh=00_AfCmLZyjYsvlVLSo_9ltwIfMajHnBAWda_uR0_wwtFujYQ&oe=637236FB
Morning Hunter
You need the help of a transmission specialist: preferably a ZF Agent your problem could be that a transmission service is due/overdue. Low transmission fluid levels, failed or failing solenoids in the box a specialist will be able to give far more information
