I have a question about how to play music from my iphone to my car?  I would like to do this via bluetooth but I only have an AUX plug in my 2008 E61. Anybody got any ideas? Thanks Paneuro.
Morning Andrew
Depends on whether you have the M system or a CCC there were posts some time ago that you need to enable music streaming in the CCC settings there were a couple of videos on you tube that showed how.
If however, you have the early M system I think you're stuck
Hi Dave, I think I am stuck!  No idea what CCC or M means but all I can find is an AUX plug in the centre arm rest. thanks Andy.
Morning Andrew
They are the "Type" designations for the Infotainment systems fitted to the 5 series models. Just looked at your post again with your car being a 2008 model (should have seen earlier Dohh) I believe your model has the CCC system so you should be able to enable Music streaming using the cars onscreen settings menu and your rotary controller. As I said there were some "How to" videos on the Internet Google is your friend
The early system (as fitted in my E53 4.6is) I can only connect through a wired Aux connection. Bluetooth for phone but no music streaming. Very rarely used in the E53 the engine makes the best sound. My E70 has music streaming enabled when I brought it so I have never looked but also not used as I am a boring old boy who rarley listens to even the radio these days
Good Luck it is in there
