i am looking for a rear subframe for a 2005 x5 3.0 L diesel e53 . cant find anything , would a  2007 or 2008 model e70 subframe fit without any mods ( part numbers differ }
Morning Graham
Simple answer is no, I have not heard of it being done though if you can get measurements of the mounting points you may be able to make a decision.
I believe ALL X5 E53 models used the same sub frame just Diff and drive shafts being different. I take it you have checked realoem then double click the part number you should get a list of alternates. Just had a quick look and part Number 33316770459 was E53 and 33316863815 was E70 it doesn't seem to indicate any cross over on late/early models
i just received a quote from that same company through breaker link search, i am just about to order it now, thank you all very much for your help
      Alloy wheels
    • Gouden earned a badge
    • Markc earned a badge
    • Neil Stokes earned a badge
    • Mish earned a badge
    • Paul M went up a rank
