I have installed this amazing product to my car and it works flawlessly but i need to know that how do I switch the new Android system to the original BMW CCC/CIC interface?
Morning Kashif
I have an Erisin system in my E70 which looks very similar, I can use the Menu button to toggle between systems or touch the screen (off the Icons) in either system to switch between them
I would think yours should be similar
Hello Dave, Yes, you retain all the original features. You can use iDrive to scroll between the apps and use the steering wheel control. You can also use touch to operate it.
Morning Kashif
So if you touch the screen Off the Icons you should move to the original BMW menu
That's how mine works, also if I push and hold the Menu button on the rotary controller
      3.0i starter motor
    4. 0
      Bmw x1 2012 won't start
    5. 6
      X3 2.0 automatic
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
