Infotainment Advice
Hi Guys,
I am a complete novice at idrive systems so bear with me.
I just purchased a 2018 BMW 118i M Sport and its the first BMW I have ever owned, so I was looking at the Infotainment system and the maps seem very out of date, also would be great to have carplay use as that is what I had in my old car.
Looking on the internet it seems as if there are options to enable carplay/upgrade maps using a code and files via USB, depending on what infotainment system you have. (I think I have got that right) but I cant work out if that is possible with my setup, Its seems to be an ID6 based system.
I contacted one guy online and he said it was not possible, so really I am looking for advice on how I can confirm what I have, what is possible and then what options I have available to me.
Any advice appreciated, as I said completely new to all this and its the fist car I have purchased in the last 10 years!!
Morning Matthew
Welcome tot the Forum
You can check one of the online Vin De-Coders which will give you a Build sheet for your car, that is important in case the Original buyer may have ordered something different to standard. Look for a code like S609A which is the Professional Navigation/Radio
Once you know what you have then you know what maps to purchase obviously OEM will be best but expensive from a Dealer, there are others out there supplying non OEM maps and codes not tried them myself.
Apple car play I am sure you can enable that through the cars settings. Check for you tube help
Thanks for the reply Dave,
Mine is showing as the S609A, Which is showing as an ENAVEVO everything I can find online seems to suggest it cant be enabled.
Guess I will look at an MMI box or upgrade the screen if all else fails.
Matt
