Hi I was wondering if any knows what these connectors are for I recently purchased a 118D with the M47 engine no lights are on the dash but I found these plugs tucked away in the drainage under the bonnet when removing leafs they seem to stem from the main wiring harness that runs along the drivers side of the car and the plugs have the wording Tyco on them
6 hours ago, Greydog said:
Hi Dan
Have you checked www.realoem.com
Hi Dave long time no speak
Yes mate I've looked on there I dont really understand wiring diagrams unfortunately but from what i have seen doesnt really give me an idea unfortunately
ok so after some searching on the web I believe that the plugs are for the heated washer jets on the bonnet ill give you an update tomorrow and let you know if this is a solved case or not
SOLVED IT
      3.0i starter motor
      Bmw x1 2012 won't start
    4. 6
      X3 2.0 automatic
    5. 6
      X3 2.0 automatic
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
    • DDONNY earned a badge
