Hi all, I’m new to the group. I have a 2009 X5 3.0d m57 with a loud knocking noise from the top end of the engine and white/grey smoke from the exhaust.
I have tried unplugging the injectors one by one but the noise remains, it seems to becoming from the top front of the motor.
Any suggestions would be welcome
Morning
A diagnostic scan needed to be sure, have all the injectors been tested wiring loom checked
Diagnostic scan shows nothing, I’ve unplugged the injectors one by one but the noise remains. I had the injectors tested and all seemed fine but I know they can suddenly fail. I’m thinking it might be a stuck or broken follower, so I’m going to take the cover off and have a check.
Do these suffer from oil galleries getting blocked
Just managed to get injector 5 out as it was stuck fast and I didn’t have a pull, now it’s out I’ve found this which I’m guessing is going to be my problem. A very badly seated injector
Looks like you may have found the bad one check if you can change only one? I seem to recall reading they need registering
But then at my age I could be wrong
  • 1 year later...
      850i for sale no reserve
      Bmw x4 2015 angel eyes
      Steering lock query
    5. 3
    • drew lemke earned a badge
    • bpd1984 earned a badge
    • Mikeyladders earned a badge
    • Martyn58 earned a badge
    • Trevor1 earned a badge
