Only 1 speaker working carnt find amplifier ont in rear has I thought of ytube
Morning Brian
If your X5 is fitted with the external Amp you will find it in the right hand rear cubby in the boot. If you don't have an external amp then the issue is either the actual speakers or the BM54 radio unit under the floor in the boot.
BM54 and speaker issues were fairly common at one time, check all the speakers with a multi-meter the BM54 unit can be changed or repaired
11 hours ago, Bri1 said:
Thanks for info will check later👍
It’s the bm 54 thanks
    5. 2
