X6 2012 Wing mirrors folding but not tilting
The E70 is misbehaving again !!
Well spent an afternoon in the sun finding and fixing the K-can faults just need to get at the Brakes now Dave -
….. and mine is working….. give it 10 minutes and normality will resume mate…. -
Stupid question, but is the airbag switched off? This would cause there symptoms? -
Hi. You have diagnosed the issue correctly. its the occupancy sensor in the passenger seat. possible it is a broken wire in the seat giving a high resistance which is why it’s reading faulty with the bypass switch? -
Camshaft stuck issues
Need some help - daughters car broke down 2012 1.6 M Sport - AA said at first coil pack but them timing chain had stretched- the below is what the garage has done and now cannot find the fault we are getting desperate to get it sorted 😩😩😩 BMW 116i N13 Original faults misfire cylinder 4 Camshaft angle offset with crankshaft Removed coil from cylinder 4 found damage, replaced coil and plug, fault cleared. Camshaft angle offset with crankshaft reoccurred Removed rocker cover - found timing chain loose- damage to guides Replaced timing chain, tensioner, guides, rocker gasket Cleared faults Fault - inlet Camshaft stuck Charge pressure control switch of as consequence Removed and replaced both inlet and exhaust vanos hubs, rocker gasket Cleared faults and retested 1/2 Fault reoccurred inlet camshaft stuck and charge pressure control switch of as consequence Removed and replaced inlet vanos solenoid Cleared faults and retested Fault reoccurred inlet camshaft stuck Charge pressure control switch off as a consequence
