Morning John
Are you sure it is the Module I changed the sensors on both my X5's with sets from Amazon all worked straight from the get go. The faff was Wheels Off Tyres Off to fit them.
If your certain it's the Module check www.realoem.com, put the last 7 digits of your Vin into the search box it will bring up your model then find the item you need.
When you have found your item double click the part number and it will show a list of alternate numbers that can be used and models they were used in. Then search the Net using the part number/numbers for what you want. Check the specialist dismantlers also.
  • 2 months later...
      Misfire at 2000rpm
      Bmw 116d 2011 her fault codes
      Misfire at 2000rpm
    5. 2
      X5 wanted
    • rjrive earned a badge
    • welshchy earned a badge
    • JohnLC earned a badge
    • John Kup earned a badge
    • Alik989 went up a rank
