What should I be checking if the air con isn’t working.  The light is not illuminating.  We have just bought the mini and would like to say hi to everyone.
Hi John
If your lucky it just needs a re-gas if your not lucky and it needs parts due to leak it could cost a bit.
If you brought from a Garage/Dealer tell them and see what they say (they ought to fix it)
If it was a private sale it's tougher, Kwik Fit often do Air Con Re-gas deals worth giving them a try the machines they use vacuum out the system check it holds a vacuum so will only re-gas if there are no leaks. All Aircon systems loose a little each year particularly if the previous owners turned it off for lengthy periods. Bad practice the seals dry out allowing gas to leak.
Hope this is useful
      850i for sale no reserve
      Bmw x4 2015 angel eyes
      Steering lock query
    5. 3
    • drew lemke earned a badge
    • bpd1984 earned a badge
    • Mikeyladders earned a badge
    • Martyn58 earned a badge
    • Trevor1 earned a badge
