Brake judder
hi, I have a 320d 2016 touring which I have break judder issues. The disc’s and pads have been replaced 3 times in six months, each time everything is fine for about 1.5/2 K then the problem begins to develop again. Disc’s don’t seem to be over hot and I experience considerable noise when breaking at speed. Don’t want to have disc’s changed again without more investigation. Any ideas would be most appreciated.
thank you
craig.
Morning Craig
Have you checked the Brake Reaction struts if the bushes are wearing that can cause vibration when slowing
How many miles has the car covered I have seen bushes on the way out at around 60 to 70k
5 minutes ago, Greydog said:
Morning Craig
Hi Dave, thanks for your reply. The car has covered 125k. I have booked it in for investigation I’m not prepared to have the disc’s changed a fourth time without a closer look. I’ve also been told to get the carrier pins checked.
 I will take your thoughts up with the garage on Friday and let you know the outcome.
many thanks.
craig.
