Hi all, I’d like to replace the star head bolts and washers in the engine bay, just the ones you can see.  There appears to be 2 different sizes, does anyone know what the sizes are?
Morning Simon
Check www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model.
Then search the sections Trim etc for what you want. Once you have part numbers search using the part number on Google for suppliers and costs, don't forget BMW your laocalm Dealer is often not as dear as people assume.
      Z3 airbag wiring,
      Z3 airbag wiring,
    5. 2
    • Andrewkuk earned a badge
    • JayMe earned a badge
    • DAW90 earned a badge
    • Max123 earned a badge
