Carly app
Air bag fault
Hello Dave Thank you for the respose. I will try to locate the connector and clean them up. Could it be the head air bag and not the door air bag that is faulty? (BTW the car is a LHD). Considering there is no oil thermal sensor could the “Thermal Oillevel Sensor” be a faulty oil level sensor? I have tried to instal the 1.4.0 on my laptop but I gave up after 3 hrs in trying. I could not find the correct drivers for the software. Dimitri -
Air bag fault
Hi Demitri Your car has an Air Bag in each door so front right would be in the Drivers Door (UK) Passenger Door (LHD) I would check the Loom connections continuity through the door it could be a broken wire in the loom (make sure you disconnect the battery first) The other faults could be as simple as a corroded pin or poor earth, the Thermal Oil sensor fault may clear when earths and other connectors are cleaned up Do you have INPA or BMW 1.4.0 they will help a lot Dave -
Drivers side wiper not flush
My x5 drivers side did this and it was the spring had lost its tension. I just bought another from eBay and fitted it in 5 minutes. job done! -
Hey, Just seeing whether there is a common problem or if someone has an easy fix? My drivers windscreen wiper doesn't sit flush to the screen when moving, leaving patches on the glass. I have replaced the wiper blade, and had a go at bending the arm, but the problem still remains. Any hints or tips would be great appreciated. -
Weird X5 Top End Noise
Hi guys, turned out it was the 'Idler Pulley' in the belt. Local autoshop figured it out. $100 repair. Thanks again for your help, appreciated! Norm.- 2
