Can’t get insta D to show fault codes
![](https://static.aciresource.com/assets/disclosure/ebaydisclosure.jpg)
Faults: B7F316, 32D, 32B.
Hi Dave. I have had another look at the TCU and replaced the unit. After clearing the codes and restarting the ignition I get the following fault code:B7F317 "GPS aerial Short Circuit to ground" I know that in previous post you mentioned the earth connection, do you know where it is? Could it be one of the four terminals that go from TCU to the Shark Fin? If so any idea which one! It seems to be that you cure one problem and endure another!! Cheers, Ray. -
Garage recommendation, Essex
Hi all, I hope you are all well! I thought I’d let others know about my positive experience I had with Precision drive near Southend airport. I was recommended by a friend, who had his E90 updated a while ago. I had messaged Chris at precision drive about getting my F36 updated & addition of CarPlay. He replied with the cost & answered any queries I had. Dropped off car & left it with him. I got a call after 1.5hrs to say the whole car had been updated but there was an issue whilst installing CarPlay (he doesn’t yet have dedicated broadband at his workshop, phone tethering wasn’t sufficient) He has kindly offered to come to my house & apply the CarPlay at a later date. It turns out that my cars never had any software updates applied since new! Instantly I noticed the shifts were smoother & engine was quieter. Should anyone else require their cars updating give Chris a message/call (search Precision Drive) I paid £120 for whole vehicle update, £60 to be paid at a later date for CarPlay activation.- 1
water pump whistle
OK, so had the stethoscope test done and yes, water pump had gone. Not a bad life to be fair, 97K mls. New one installed and also had the belt changed as well. Onwards.......- 1
Rear View mirror has come off windscreen screen
Cheers Dave, took some planning to ensure it was in the correct position though.. -
X1 problems with connectivity and Carplay
Hi John Welcome to the Forum Never come across this before it will be interesting to know the solution That is assuming BMW will tell you 😅 Dave
