F30 Firmware version
2008 E61 start issue
Looking for some help. 2008 BMW E61. 520d Car died and wouldn’t restart. Issue looks to be throttle body however have replaced that and same issue just cranks. Battery went flat with all the cranking and checking around. then worked and started after charging. Drove 20 miles or so. Thought all fixed, next morning. Started and died like before. Now won’t start. But if throttle body is unplugged it’s starts and drives. HELP -
Nav display
Morning Carole Welcome to the Forum This is a new one I guess you have tried all the menus in settings on your iDrive? Then as your in a 22 model have you asked your Dealer for help I know it doesn't always work but worth a try Good Luck with the search Dave -
Nav display
I want my backup camera display on my 2022 X5 to cover the entire screen. How do I get rid of that partial camera display on the far right. It's a hindrance to human and vehicular traffic.
