Morning Timothy
Take a look at www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model then search the sections for what you want (Fuel Preparation) the small exploded drawings should help with location and fitting also the part number (if buying a replacement)
Also double click the part number and it will give a list of alternative part numbers and models it was used on.
      Alloy wheels
    • Gouden earned a badge
    • Markc earned a badge
    • Neil Stokes earned a badge
    • Mish earned a badge
    • Paul M went up a rank
