Thanks for accepting me. I’ve just bought a very tidy 2004 X3 2.0D Sport as a project to work on through winter. The brakes are very spongy and I generally rely on a prayer and decent grip to stop it. Can anyone advise on brake upgrade options or might they just need looking at. I’m mechanically incompetent and will be paying someone to do the work so any good specialists around Derbyshire would also help. Thanks in advance
Morning Steve
Spongy brakes are normally a sign of poor maintenance and can be Brake fluid needing changing, Flexible brake pipes in need of changing (ballooning) Servo leaks check the Vacuum lines and non return valve at the servo.
Either find a Good Independent or BMW Specialist will be not to far away, there is a Register of BMW Specialists so check the Internet for their locations.
If the Brakes have been ignored it is a probability that many other service parts have been as well
So many people think an Oil and Filter change is a service !! sadly so do more than a few garages
Good Luck with the Project
4 hours ago, Greydog said:
Morning Steve
Thanks Dave and much appreciated, Ill make sure the mechanic checks it out fully. I look forward to being involved in the forum and seeing my pan come to fruition
      Alloy wheels
    • Gouden earned a badge
    • Markc earned a badge
    • Neil Stokes earned a badge
    • Mish earned a badge
    • Paul M went up a rank
