Hi all… basically the glue on the headlights is not shifting. I have fired a heat gun enough to melt the light fitting and tried to bake it…. Just cooked the light….
anyone got a solution to split the light so I can fit some halo lights for the wife.
Its a pre facelift model. 2002. Lights  are 2003 I believe.
either that, or does anyone have a standard set which have been split?
Morning Stu
BMW strikes again 😅
Up to 09/2002 (if my old brain remembers) the glue could be softened and the lamp lens separated, seems someone in BMW didn't think much of that, I mean customers customising a BMW so the glue was changed.
There is a clock face on the plastic casing which should indicate the manufacturing date. I have read of a Dremel being used on the glue line to separate the lens then refitted using a hot glue gun but never done it myself. You could hunt for a light set with a pre 09/2002 date or as you have a set try a Dremel first
Good luck Mate
Yeah, your right about the pre 2002 lights.. they changed to a near on unbreakable glue called secure flex or something in 2003 just because they wanted to… and stop condensation… and nuclear fallout getting in.
I think I’ll get a dremel and maybe a couple of days away from the kids and invite the inventor of the glue over…
Maybe it’s karma from when I put tiger seal on my mates tyres for a laugh and he burnt his clutch out trying to move the car … ended up sawing the tyres off the floor! … it didn’t have much torque 😂😂😂
  • 1 year later...
Well…. It begins!
The dremel was useless and just kept snapping blades, so I went for the next option….
2000 watt heat gun….
4 hours later I have a melted set of lights and some angel eyes in position. I managed to pull the wire out of one of the halos so I’ll get the soldering kit out 🙄
once all the halos are in and working, I’ll fit the new lenses and mould the mos sharpen bits back again… hopefully!
Morning Stu
That looks brutal 🤣 nice and bright though
You didn't have the metal high speed saw blades then 🤣
      No emergency door lock
    4. 6
      Bmw x4 2015 angel eyes
    • First Bima earned a badge
    • frankolinno earned a badge
    • Oldestdog earned a badge
    • Mikeyladders earned a badge
      Reacting Well
    • Super Bmw earned a badge
