Hi guys, I’m building a resto mod (no it’s not a BMW🤦) but it will be using a BMW engine & box.
My question is; I’ve got an electric steering rack from a ’59’ plate E87 2.0 petrol, as far as I’m aware it wasn’t coded off of the car.
Does anyone know if I will be able to wire the rack in a similar way that the rallying boys do with electric power steering columns from the Vauxhall Corsa & french poo Clio’s? If yes can anyone help me with this or point me in the right direction?
I know some may think just use the EPS column, but the BMW rack is a perfect fit (bump steer, Ackerman ect) plus the EPS racks are a bit rubbish.
Morning Robert
Sounds an interesting project
I did read an article about swapping EPS into a normal power steering BMW a few years ago. From memory it was fairly painless just requiring some Vin registering (not real coding) to allow the rack to operate with full servotronic function
I will try and find if there are any other information
      Sat/nav 8.8 screen upgrade
    3. 13
      Air bag fault
    • Mish earned a badge
    • Bmw90 jack earned a badge
