Greetings,
I was trying to add a new key to my bmw f10 2012 cas4
Using xtool d7w and kc100 i don't know why i decided to click on cas upgrade but atter that car fully disconnected from everything no ignition cant turn the car off no keys recognised cant even open the trunk to disconnect the battery. Error: swrl code mising
I don't know what is the next step now and how can i fix this
Morning Omer
Check Stu's post on Keys and registration
Can you get into the car at all? There should be an emergency release in the boot if you can either drop the seat back or have a ski hatch behind the centre arm rest
Last don't know why but your post is in the Classic section and should be in the 5 series section
If you cant sort it you need the help of someone who really knows how to use ISTA/INPA a  BMW Specialist or a BMW Dealer be warned they will not be cheap
      Sat/nav 8.8 screen upgrade
    3. 13
      Air bag fault
    • Mish earned a badge
    • Bmw90 jack earned a badge
