Need advice. There is a noise coming from the turbo charger in my 2007 Alpina (72000 orig miles). Is there a cost effective way to repair (or replace)? Thanks for any suggestions!
Hi Antonio
I have never seen a B7 in the flesh only read about them, from what I remember the engine uses modified twin scroll Turbo chargers so will not be cheap to repair/replace
I also thought the B7 was introduced in 2016 so not sure what model you actually have?
      Noise
      Noise
      Misfire at 2000rpm
      Bmw 116d 2011 her fault codes
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
    • welshchy earned a badge
