Hi Paul
Are you sure the heater matrix needs flushing if you are then the nearside of the engine bay are two hoses one from the bottom of the header tank the second is attached to the Auxiliary water pump. Disconnect them and flush from there
However I have known the poor heater performance to be a failed Auxiliary water pump worth checking that first.
